Hypertherm sync 45 hook up question
Moderators: cnckeith, Joey
cardin3
CNC Control System Serial Number: 7550
Post by cardin3 »
I just purchased a new sync 45. I don't want to do something stupid. Are the arc transfer wires used? I understand the divided voltage (thc) and the torch on and off.
Centroid_Jacob
Web Developer
Re: Hypertherm sync 45 hook up question
Post by Centroid_Jacob »
I moved this post to the Plasma Forum.
Joey
Plasma/Laser Lead
Post by Joey »
The THC will act as your ARC OK/ ARC Transfer.
But Hypertherm Recommends using their ARC OK/ ARC Transfer For the most accurate Pierce delays.
I usually like to hook up Hypertherm's according to their recommendations.
cardin3
Post by cardin3 »
I there a centroid wiring diagram? and any configuration requirements?
Joey
Plasma/Laser Lead
Post by Joey »
You can reference the Everlast arc okay connection.
https://www.centroidcnc.com/dealersuppo ... 195.r1.pdf
There's 2 arc transfer pins on the hypertherm cnc communication port. One will connect to Acorns Com. The other will connect to the Acorns Input
Pin 12 and 14 on the Hypertherm CNC Com ports are the ARC transfer pins.
Connect pin 12 to the Acorns Common.
Connect pin 14 to the Desired Acorn Input
Just assign the input as arc ok in the wizards input definition menu
cardin3
Post by cardin3 »
Ok. Sounds good. Thanks for the reply. I will get it wired up and check back in.
cardin3
Post by cardin3 »
One other question. Pin 13 on the powermax is a ground pin. Should I contact that to the ground on acorn.
Joey
Plasma/Laser Lead
Post by Joey »
That should be connected to the shield on the Hypertherm CNC Com cable.
cardin3
Post by cardin3 »
Ok. It's cutting!! Every thing seems fine.i have a question about book setting voltage VS actual voltage. I'll start a separate thread.
Again, thanks so much.
Mike
