X axis moving from right to left in the X+ direction
drhodes4601
CNC Control System Serial Number: 20551
Post by drhodes4601 »
Hello again.
Just finished my first paid program for my antique Bridgeport Series 1 CNC retrofit. When I program an X+ move I am used to the table moving left to right. On the CNC graphing program, it moves correctly. When I run it on the Centroid it runs opposite, right to left. Is this just an easy parameter change to correct? Thanks!
Danny
Bridgeport Series 1 CNC Retrofit 3 axis mill
Controller M400S
Serial 20551
CNC10 v1.51
Re: X axis moving from right to left in the X+ direction
CNC directions are defined by the direction the spindle "moves". X+ is the spindle moving to the right. On a machine where the spindle is stationary and the table moves, then X+ would be when the table moves to the left causing the spindle to appear to move to the right.
It sounds like your machine is wired correctly.
drhodes4601
So when I program let's say G1 X2. F10., and I am starting at X0, it should cut 2 inches toward the right edge of the part. But instead it is cutting 2 inches towards the left side like a mirror image.
Here's a thread with more detail on the correct machine tool axis directions.
https://centroidcncforum.com/viewtopic. ... xis#p28437
Post a report file so we can see how your mill is configured. A video of what it is doing vs. what you expect it to do would help.
