Wrong tool-offset calculation with Emcoturn 120 ( Rear Tool-Turret)
Hey guys,
i just upgraded to 5.10 from 4.86. And it seems like i found a bug, but i can't say if it's only since 5.10
I am using "Horizontal Lathe, Rear Tool Approach" with a greycode-Tool-Turret for my Emcoturn 120.
After installing 5.10 i did a new setup via wizard as suggested in the installation-manual.
I entered 3.05mm Z Style Size in the wizard, as my probe has an "elephant-foot"-tip with dia 10mm and 3.05mm width.
Then i measured all my tools in the turret. To not make any errors with my touch-probe, i have been using the microscope of Emco. This is mounted to a fixed position and has got a crosshair, where you set your tool-offsets with.
So i switched to T0101, jogged that to X0 Z0 of the crosshair (outer contours touching crosshair from approaching direction) and there i set X- and Z-Ref.
Then i switched to T0202 and jogged that to X0 Z0 of the crosshair. There, i clicked on "Measure Offset Z" followed by F10 for manual setting.
The same i did for "Measure Offset X"
I repeated this procedure for all my tools, and then i rechecked everything by switching to every single tool again and entering a G0 X0 Z0 command.
BUT:
All OD-tools have been moved to X0 Z0 of the crosshair correctly.
All ID-Tools have been positioned with a 3.05mm Z-distance in front of the X0 Z0-crosshair!
So every ID-Tool has a tool-offset of 3.05mm too much in Z., for example 23.000 instead of 20.000
To clarify if these are the 3.05mm from Z Stylus Size in the wizard, i changed that value in the wizard to 1mm.
Then, i measured the ID-Tools again like before (ID-Tools are tools #4, #5 and #7 here) and after doing that, a G0 X0 Z0-move positioned all ID-Tools only 1mm away from the X0 Z0-cropsshair.
I rechecked that with 0mm for Z Stylus Size, too, and with 0mm Stylus Size the ID-Tools are measured correctly and become positioned perfectly to X0 Z0 in the crosshair, just like the OD-tools.
That looks like an error with measuring ID-Tools.
So i changed Tool 7 to OD (i had to adapt the nose vector-number, too) and then it gets measured and positioned correctly.
Either the ID/OD-setting or the nose-vector seems to cause this?
Then i re-changed the Z-Stylus-Size to 3.05mm and just edited the wrong measured Z-values of the ID-tools by hand (just calculated -3.05 for every ID-Tool-Z-Value) and now the ID-tools get positioned correctly.
I attached a report, but just to mention: I already changed the Z-Values of the tool-offsets here. JTM
Best regards,
Marc
BUT:
Best regards,
Marc
- report_80F5B5B922D4-0211225687_2024-06-01_16-33-27.zip
- (890.26 KiB) Downloaded 44 times
German-speaking, so please be patient with my english-skills
Re: Wrong tool-offset calculation with Emcoturn 120 ( Rear Tool-Turret)
hello.
thanks for posting the report.zip
the error logs show un workable Communication errors.
fix these first.
(4) 06-01-2024 16:28:50 946 PC resending # 443
(4) 06-01-2024 16:28:51 907 Z axis travel exceeded
(4) 06-01-2024 16:29:06 944 MPU requested resend # 41
(4) 06-01-2024 16:29:06 946 PC resending # 445
(4) 06-01-2024 16:29:33 944 MPU requested resend # 42
(4) 06-01-2024 16:29:33 946 PC resending # 448
(1) 06-01-2024 16:29:36 452 Ethernet Communication Error, See Tech Bulletin 270
(4) 06-01-2024 16:29:52 944 MPU requested resend # 44
(4) 06-01-2024 16:29:52 946 PC resending # 462
(4) 06-01-2024 16:29:55 907 Z axis travel exceeded
(1) 06-01-2024 16:29:56 452 Ethernet Communication Error, See Tech Bulletin 270
(4) 06-01-2024 16:30:02 944 MPU requested resend # 45
(4) 06-01-2024 16:30:02 946 PC resending # 467
(1) 06-01-2024 16:30:03 452 Ethernet Communication Error, See Tech Bulletin 270
(4) 06-01-2024 16:30:09 907 Z axis travel exceeded
(4) 06-01-2024 16:30:13 944 MPU requested resend # 46
(4) 06-01-2024 16:30:13 946 PC resending # 469
(4) 06-01-2024 16:30:15 944 MPU requested resend # 47
(4) 06-01-2024 16:30:15 946 PC resending # 471
(1) 06-01-2024 16:30:29 204 Exiting CNC...Normal Exit (66)
(1) 06-01-2024 16:30:36 199 CNC Started
(4) 06-01-2024 16:30:40 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 06-01-2024 16:30:40 944 MPU requested resend # 3
(4) 06-01-2024 16:30:40 946 PC resending # 164
(1) 06-01-2024 16:30:43 CNC12 Lathe v5.10
(4) 06-01-2024 16:30:43 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 06-01-2024 16:30:43 944 MPU requested resend # 6
(4) 06-01-2024 16:30:43 946 PC resending # 301
(4) 06-01-2024 16:30:47 9033 Reset Initiated, Press Reset to Clear
(4) 06-01-2024 16:30:48 4032 Reset Cleared
(4) 06-01-2024 16:31:32 944 MPU requested resend # 7
(4) 06-01-2024 16:31:32 946 PC resending # 303
(4) 06-01-2024 16:31:36 944 MPU requested resend # 8
(4) 06-01-2024 16:31:36 946 PC resending # 305
(4) 06-01-2024 16:31:56 944 MPU requested resend # 9
(4) 06-01-2024 16:31:56 946 PC resending # 312
(4) 06-01-2024 16:32:25 944 MPU requested resend # 10
(4) 06-01-2024 16:32:25 946 PC resending # 314
(1) 06-01-2024 16:32:34 452 Ethernet Communication Error, See Tech Bulletin 270
(4) 06-01-2024 16:32:35 944 MPU requested resend # 11
(1) 06-01-2024 16:32:35 452 Ethernet Communication Error, See Tech Bulletin 270
(4) 06-01-2024 16:32:35 946 PC resending # 316
(1) 06-01-2024 16:33:27 Creating report...
fix these first.
Run the Centroid PC Tuner on the PC and follow all the details in TB270
https://www.centroidcnc.com/dealersuppo ... ds/270.pdf
The com-errors are solved, see my other actual thread. And i doubt these are adding 3.05mm to the calculation
The PC-Tuner ist not functional here, as i already stated in the PC-Tuner-Thread.
please post a fresh report.zip and we will use your current setup data on our in house test bed lathe to investigate your report.
Ok, so here comes the new report. I also testet the Measuring-procedure again after the ethernet-communications-errors are solved now, just to make sure. But the problem still exists. I made some screenshots again:
My Z-Stylus Size was set to 3.05mm I moved Tool #7 (ID-Tool with nose-vector 2) to a defined position in Z and measured Offset Z. Resulted in Z= -27.737 Then, in the tool-library, i changed Tool #7 to be an OD-Tool with nose vector 3 (because 2 is not possible for OD-tool) and measured Offset Z again at the same position, tool has not been moved at all. Resulted in Z= -30.788. This is 3.05(1) more than the same tool at the same position, but as an OD-tool now.
After that, i changed the value for Z Stylus Size in the wizard from 3.05mm to 0mm, restarted CNC12 and then made the same measures at the same Z-position again.
Changed Tool #7 back to be an ID Tool with nose-vector 2, measured Z Offset again. Resulted in Z= -30.788 Finally i changed Tool #7 to OD-Tool with nose-vector 3 again and also measured Offset Z again. Resulted in Z= -30.788
As i said, the tool has been at the same Z-Position for every single measuring, i just changed ID/OD and Z Stylus Size (and the nose vector of necessity)
Maybe i am doing something wrong, i am just a noob and i still don't have much experience with Centroid, but to me it seems that the 3.05mm of the stylus-size should not interfere here at all? Regardless of ID/OD or nose-vector?
Hope this helps
Best regards,
Marc
Hope this helps
Best regards,
Marc
- report_80F5B5B922D4-0211225687_2024-06-03_20-58-58.zip
- (889.09 KiB) Downloaded 47 times
thanks, good info. we will be working on this on tuesday.
also can you post some photos of your machine and setup?
would be good to post them in a photo album so they are all in one spot. google photos is good for this.
Sure, i already posted about that in another thread^^ I promised to do soon
Have been wondering myself, why i didn't do that when building that machine in 2022
I had some questions before the build, and while talking about that, i completely forgot to post the build itself after finishing it...
Just as a quick teaser:
No worries on the English.
A picture is worth a thousand words!
