Thanks Tom -
Though still pretty vague I hear you trying to express the potential importance of doing everything as in line with best practices as possible to minimize those potential future EMI headaches. That's my approach generally. I'm very close to the end of my conversion and it hasn't been a walk in the park by any means but progress is steady. Even with all my components wired up in a pile on a plastic side table, I was able to surface my spoil board and do some test Vcarve files. The kind of care I put into building the control box felt more than adequate, but now I'm being warned I missed something extremely important. I did a search of the forums for bare metal mounting plate and found 3 occurrences, all in my build thread.
From what I've seen it does appear that even people who build control boxes for hire don't always use bare metal mounting plates? It's hard to understand why something seemingly so critical is given so little coverage on the forum? Though I tend towards caution I don't tend to jump through hoops to solve problems I don't and may not have. And given that my box is fully built - it will take the exact amount of time in the future to take it apart and sand the mounting plate and reassemble it, as it would to do it today.
Here's the thing. I've been building musical instruments for 50 years and using a Shopbot CNC for 20 years. SB had its com errors and I had some grounding issues to work out along the way, but generally pretty dependable with decent tech help. I know Shopbot is not that highly thought of on the forums, and I can understand why, but it was good to me and it paid for itself many times over.
I found my way to Centroid because the ShopBot controls couldn't reverse direction to a spindle, which I need to realize my goal to implement the RapidChange ATC system. It looks like I'll be able to pull that off. I may be living some version of your "Confidence" quote Tom
- though I can't say I've felt much confidence so far.
Like life, it's a bit of a roller coaster. Sorry, I'm rambling a bit. I do know the folks on this forum are all trying to help. So thanks again for your input.
Cheers...David
