NEW Build. LMS 7x16 Lathe, Centroid Acorn.
DLAM
Re: NEW Build. LMS 7x16 Lathe, Centroid Acorn.
Post by DLAM »
Did You get the forward and reverse all worked out? You said in previous post about board only having forward.
iLefty
Post by iLefty »
DLAM wrote: Mon Mar 14, 2022 8:16 pm Did You get the forward and reverse all worked out? You said in previous post about board only having forward.
Yes if you look at the schematic I drew it shows AVI going to N/O of relay one and two and then F/R going to N/C of relay two. When relay one is called it grounds start/stop and relay two will still ground f/r. When relay two is called it will open grounding start/stop but ungrounding f/r causing it to spin in reverse.
iLefty
Post by iLefty »
I got around to machining the cross slide plate that locks the cross slide itself to the ball nut on the a axis.
Also got a chance to fire up the 3D printer for the encoder bracket so I’m gonna dive into that this weekend. All I have left to figure out wiring wise is limit switches.
All I have left mechanically is mounting the tool post. Getting close now.
Will you mount bearings on the other ends of the ballscrews?
iLefty
Post by iLefty »
suntravel wrote: Sat Mar 19, 2022 3:51 pm Will you mount bearings on the other ends of the ballscrews?
Yes. I have to turn the ball screw down some to fit the stock bracket
Miamijerry
Post by Miamijerry »
KJ-1/110 was a good find.
Does not appear to be useable on my Harbor Freight lathe.
You did well "iLefty"
iLefty
Post by iLefty »
Got my wiring pretty much done. Just need some connectors for getting out of the enclosure and have to set up the encoder but it’s working.
Have to make a tool post spacer and get the all set up and then it’s onto making parts.
DLAM
Post by DLAM »
What size enclosure did you use?
iLefty
Post by iLefty »
The enclosure is a Corsair 4000d pc case.
iLefty
Post by iLefty »
So it’s Alive. I got it up and running this morning. Have to fiddle with x as my parts are smaller then I am commanding. Not sure why.
Here’s a video link to my ig. Not sure how to upload video.
