Acorn Controller Won’t Connect – Bad BeagleBone?
TrellBuilt
Post by TrellBuilt »
I’ve been using my Acorn controller for years without issues, but now it won’t connect to the computer, just like what others have reported with older controllers.
After running some tests, it looks like the BeagleBone board is bad. My question is: can I just replace the BeagleBone board, or do I need to replace both the BeagleBone and the controller board?
Any help would be appreciated.
silver2row
CNC Control System Serial Number: 6665
Re: Acorn Controller Won’t Connect – Bad BeagleBone?
Post by silver2row »
There is a way to "debrick" the board and flash a new controller firmware to it.
Seth
P.S. may help you.
silver2row
Also, people usually ask for more data to make sure it is a faulty firmware issue.
So, prepare!
CentroidFrog
Tech Support
Post by CentroidFrog »
Here is a link with instructions on testing if the BBG is bricked, or bad in general: https://www.centroidcnc.com/centroid_di ... icker.html
And yes, the BBG can be replaced on it's own, but you will need to do the debrick procedure on the new BBG.
Another option could be using the Acorn swapout program.
For $199 you can send us your Acorn and we'll send you a replacement.
Acorn swapout info here: https://www.centroidcnc.com/centroid_di ... ranty.html
