I cannot find where in the user's manual they discuss how to get my A Axis DRO to match the actual rotation of my A axis.
Any suggestions?
Thanks in advance,
Rick
A Axis DRO versus Actual Rotation (resolved)
- CNC Control System Serial Number: 38D269533454-0111180523
Re: A Axis DRO versus Actual Rotation
The document seems to only address how to calibrate a linear axis. I did this on my XY and Z axes yesterday plus populated the backlash values. If you look at http://rick.sparber.org/ZSM.pdf page 8 you will see how I calibrate my Z axis. I'm using a stack of precision ground spacers and a finger DTI.
All three linear axes look fine. My problem is with my rotating A axis and its corresponding DRO value.
Rick
The process is identical.
Basically you command a move and measure how it went. Then take the distance displayed on the DRO and divide it by the measured distance. Start at set a part 0 for A and then jog it 360 degrees (of mechanical motion.) Let's say the DRO read 615.1234 and your move was 360 degrees.
Divide 615.1234/360 = 1.708676111.. this gives you a multiplier that you use to adjust your current revs/unit. If your current Revs/unit is set to .25 then 1.708676111 * .25 = .42716902777.... <--- The new value for your revs/unit on A axis. (Keep in mind that changing revs/unit changes your part zero so you will want to re-zero).
It all finally got through my thick head. XYZ and A now work correctly.
Thanks to all!
Rick
https://youtu.be/gAalEkMSsoY
Thanks to all!
Rick
