762x51 wrote: ↑Sun Aug 06, 2017 4:30 pm
I'm will be retrofitting a Techno-Isel CMP 3020 router with an Acorn and need to monitor 6 limit switches.
Is the wiring shown in the attached drawing OK?
Also, can the RL2 relay output be programmed to start/stop the router motor?
Like others, I look forward to seeing the ACORN's manual and I hope questions like this will be answered in the manual.
Orin
Another option is to only monitor each axis home switch and then properly setup the software travel limits. CNC12 won't let you go past the software limit. The only caveat is that if your stepper stalls and looses steps, and you end up at the end of the travel, you could fall short of the actual travel and CNC12 stops the axis OR you could overshoot and the machine hit a hard stop. On stepper driven machines, in most cases this isn't catastrophic.
If you are running hybrid steppers with encoders, (or servos in the case of Teknic Clearpath SDSK, DMM Technology etc.) where the loop is closed by the driver, then this would work well.
My Dyna DM2400 test machine only has limit switches at the home end of each axis, and the D&M4 has no limit switches at all. On the D&M4, I jog the machine to marks on each axis, set home and the CNC software takes care of travel limits from there.
So you see the software is very flexible given a particular application. In the case of limits, it can help conserve inputs. If you don't need the other inputs, then by all means use one for each limit
As far as a manual. There are many wiring diagrams available, it is hoped that between them and this forum, users will find all they need to know. Acorn itself is a pretty simple device as far as inputs and outputs go. It was intended that way. It is NEW so it will go through some growing pains initially, we can all help make it better by sharing our experiences,
