Posting this as a new topic as I "highjacked" another thread looking for help under similar problems. I have a CNC router that I've successfully converted over to Acorn and CNC 12 V4.82 (just did V4.82 today). My machine has been functioning properly with NC files from Fusion 360 but I am now working on my ATC. I have an HSD ES90 spindle with pnuemax 3-way monostable solenoids (this is what HSD recommends). I can run the tool release and lock functions from the PLC diagnostic menu by toggling outputs 5 and 4 which is how they are mapped in the wizard. However, I've tried running M15 from the MDI and M94 /15 with no luck. The HSD has a single output sensor (one wire) for the tool ejected, one tool locked and one for the shaft stopped. I tried wiring the tool-ejected sensor to Input 3 but never had any luck with that having modified the M15 macro several ways. I adjusted my parameters to the setting described in the 4.80 ATC instructions as follows: A) Set Parameter #6 = 1 (ATC installed)
B) Set Parameter #160 = 1 (Enhanced ATC settings, see operator manual Chapter 15)
C) Set Parameter #161 to maximum amount of tools of ATC.
With the modified M15 (attached) macro loaded I get the result (attached screenshot).
I figure I need to get the M15 macro and M16 running before I attempt the ATC macro.
