C-Axis for lathe (construction in progress)
I started to build a C-axis for my lathe.
Since my lathe is with gearbox and some lash in the gears, I decided to go with an extra drive belted directly on the spindle an be engaged with a clutch.
Setting up C axis in the Wizard is the easy part, but then you can jog the C-Axis while the spindle is running, or turn on the spindle while the clutch is engaged. Would make some funny smoke :mrgreen:
So till now the way I build some safety for this is quite simple ( I am not the best PLC programmer :D )
If P#93=1 C Axis will be displayed on the DRO as rotary axis
If P#93=512 C Axis will not be displayed on the DRO
If P#218 is set to 3 you can only jog X and Z with the WMPG
If P#218 is set to 7 you can jog C, X and Z with the WMPG (C as 4th axis)
I use OUTPUT8 to switch the clutch with M68 / M88
M52 will turn C-axis ON
; Filename: mfunc52.mac - Turn C-Axis on
; M52 macro
; Description: User Customizable Macro
; Notes: C-axis must be configured in the Wizard
; Requires: custom PLC StandardSpindleStage
; ;Inhibit Spindle when P#93=1 C-axis On - UWE
; IF !SpindleEnableOut_M || SV_MACHINE_PARAMETER_93 == 1 THEN (DoSpindleStop)
IF #50010                        ;Prevent lookahead from parsing past here
M5
G4 P1
#103=1
#104=7
G10 P1093 R[#103]
G10 P1218 R[#104]
; Output8 for Clutch ON
M68
N100
M53 will turn C axis OFF
; Filename: mfunc52.mac - Turn C-Axis off
; M53 macro
; Requires:
#101=512
#102=2
G10 P1093 R[#101]
G10 P1218 R[#102]
; Output8 for Clutch OFF
M88
N100
On the VCP is use M55 to switch ON and OFF
; Filename: mfunc55.mac - To run from VCP AUX 10 key, set p197 = 5511
; M55 macro
; Description: Turns C-Axis ON/OFF
; Notes:
; Requires: Machine home must be set prior to use.
N100                             ;Insert your code between N100 and N1000
#105=#9093
IF #105==512 THEN M52 ELSE M53
N1000
And some edit in the PLC to inhibit spindle ON if C-axis is on
IF (SpindleEnableOut_M || SpinStart_M ) && !SpinStop_M && ChuckOpenCloseComplete_M
  THEN SET SpindleEnableOut_M
; inhibit spindle with C-axis ON - UWE
IF !((SpindleEnableOut_M || SpinStart_M ) && !SpinStop_M) THEN RST SpindleEnableOut_M
IF SpindleEnableOut_M && !M37 && SV_MACHINE_PARAMETER_93 == 512 && !(OUTPUT8) THEN (VFDEnable_O)
IF  SpindleEnableOut_M && !M37 && !SpindleDirectionOut_M && SpindleBrakeTimer THEN (SpinFWD)
IF  SpindleEnableOut_M && !M37 && SpindleDirectionOut_M && SpindleBrakeTimer THEN (SpinREV), (VFDDirection_O)
Not the most elegant solution, but it works :mrgreen:
Now I must find a clutch that will do the job and figure out if I can use the spindle encoder for setting C Home....
Re: C-Axis for lathe
I ordered a build to my specs clutch from Mayr, but must wait 5 weeks now.
Was not really cheap also, nearly 400bucks :mrgreen:
Wiring for the C-Axis clutch...
nice thanks for sharing
Wiring done and did some testing to fine tune the M52 macro for a fast and save switch to C-Axis mode...
Now I get a message why the spindle can not start when C-Axis is turned on.
My first DIY PLC message :mrgreen:
Slowly I am getting a clue of how this PLC works ;)
Had a glitch when a program runs and commands M3 after C-Axis is active, it shows the message, but PLC thought it can go on :D
Now it stops the running program with the error message.
Kind of tricky to build save running functions....
Now I figured out how to set C home to the zero index pulse from spindle encoder.
G91 is not part of CNC12 lathe, so I used the current position for incremental moves.
Would be better to have the C axis continuous moving to the zero index, but could not figure out how to do this.
Maybe I must find a way to trigger an input with the encoder zero index?
Than I could use M105 /C P#
Any ideas how to do this?
But for now it works to home C allways to the same position.
; Filename: mfunc57.mac
; M57 macro
; Description: Set C-Axis Home to Zero Index from Spindle Encoder
; Notes: C-Axis must be turned on
; M200 only for testing, remove later
; #5043 current position C
; #23405 index pulse from spindle encoder
G98
N100
#104=#5043+0.1
G0 C[#104]
N200
IF #23405==1 THEN GOTO 300 ELSE GOTO 100
N300
#105=#23405
M200"Spindle Pos=%f"#105
#102=#5043
M26 /C
#101=#5043
M200"C set from%f to 0 CPos=%f"#102#101
I got the 5:1 gearbox today, and made also a quick drawing, how the pieces are coming together and could be mounted on the spindle stock.
Easy Acorn C-Axis bolt on :mrgreen:
Spartan117
Post by Spartan117 »
If you are not careful, the lathe will tip over from all the attachments :D
I wish i could give you some tips for your PLC-problems... But hey, even the centroid-pros here seem to be stumped for that kind of problems, so how should i be able to help you :D It's a pity, that PLC-thing could be such a powerful tool with a little bit of support for certain questions.
German-speaking, so please be patient with my english-skills :)
