Hi all!
I have been using my CNC Plasma Cutter for a while now. The only issue I am running into is when cutting on sheet metal or other thin metal that has some warping, my cuts do not turn out great. I have been looking for an affordable height controller option for a while now. I stumbled across the Centroid Products but I tend to be hesitant towards these purchases if I do not know much about them or have heard of anyone I know using one. These products look great and have a lot of support, but I want to ensure that for my machine, it would be possible to install the Centroid Acorn Torch Height Controller. Or if anyone has done anything similar to the type of machine I have. Wondering if it is possible to install the torch height controller and the difficulties of doing so. Any advice or feedback would be appreciated!
CNC Plasma Cutter Controller: Burny Phantom
CNC Cutting Table: Cutting Systems Inc.
Torch Height Question for Cutting Systems Table
- Plasma/Laser Lead
Re: Torch Height Question for Cutting Systems Table
Thanks for posting! I've got a couple questions for ya. What brand and model of Plasma Power Supply are you using? Does this setup currently run a THC? Does the Power supply have a Divided Voltage output?
Check out some of the threads here in the Plasma forum for results with thin metals. Jeff's Google album has some videos and good quality pictures of 16GA steel jobs. Jeff's Username is jcolden. His Album is .
Can you post some picture of the unfavorable cuts? Curious whether the issue is high speed XY motion or Z movements with THC.
- Plasma/Laser Lead
After rereading your post looks like your not currently using a THC. Acorn THC needs a Divided Voltage output from your Plasma Power Supply. If you could relay the MODEL of your Plasma Power supply and what CNC Interface Connections it has, that will determine if Centroid Acorn with THC will work with your machine. Best of luck!
that old analog setup . Frend of mine knows owner of that company cutting systems inc it near me in ohio . first off that table most likely not designed for speed needed to cut 16 gauge based on the pic I'm guessing that old Hypertherm 120 torch no cpc output the setup designed for thick cutting steel . cutting system not known to build good table infarct one model buy Wescott they sell that junk. were AKS down street is top dog . we need more info on torch model and max ipm that table can do
