Anyone have some suggestion on how to install a spindle encoder on this type of milling head?
thx
Tips for installing spindel encoder on my Acorn converted Deckel conversion
Re: Tips for installing spindel encoder on my Acorn converted Deckel conversion
Do you have a drawing of the milling head?
On the first sight maybe under the grey cap on top could be a place to mount a timingbeltpulley.
That looks like a pneumatic power drawbar, so it's quite possible there's no place you could fit an encoder. If the right angle(?) drive to the vertical head were 1:1 ratio, perhaps you could fit one on the horizontal drive shaft, or fit a drive pulley for one. You probably won't know what's possible without drawings or dismantling what you've got.
