I have my origin set at the back left top corner of my stock in Fusion 360. When I go to touch off and set my axis under part setup, I approach from the left for X and from the back for Y (facing the machine). This should have them intersecting at the back left corner. This appears to coincide with photos of the axis directions on the selection screen to set those locations.
When I start to run the program, the machine jogs in the wrong direction even though each axis goes the correct direction and respond appropriately when manually jogging.
Experimenting a bit, I tried to touch off the stock on the right side for X and the front side for Y, while maintaining the left / back configuration in Centroid, and tool path runs perfectly.
Am I completely misunderstanding the machine's definition of front vs back and left vs right, or is this a configuration setting I have set up incorrectly? Or something else?
Machine Components
- Base Machine PM-25
- Driver (X/Y) Stepper Online Closed Loop CL86T
- Driver (Z) Stepper Online Closed Loop CLA86T
- Stepper (X/Y) Leadshine CS-M22331-L-S (Nema 23)
- Stepper (Z) Leadshine CS-M234120 (Nema 34)
- Power Supply (X/Y) Antek PS-5N50 - 500W 50V Power Supply
- Power Supply (Z) Antek PS-5N84 - 500W 84V Power Supply
- Acorn Controller Board
I've attached the requested Report Zip per the pre-post instructions. I can supply any photos or screenshots if necessary.
