I built a gang tool lathe some years back and it is dedicated to 4 jobs. The tooling setup never leaves the table.
I am sure that the updates are 4 or 5 versions old if not older. It works well for my needs so I leave it alone.
I powered up my system and turned on the remote and the screen is blank all but the battery level and signal strength indicator.
There is a little square that blinks when I rotate the MPG wheel, that is all I get.
I replaced the battery, I moved the antenna to other USB ports and restarted the system mutable times. Is it dead?
Wirerless Remote note working <install Pro License>
Re: Wirerless Remote note working
In you report file, what is the value for Parameter 218?
On the F7/Utility -> F8/Options screen, what license level do you have active?
I fund the issue. The wizard Is changing it's self back to NO MPG.
https://centroidcncforum.com/viewtopic.php?f=60&t=4508
that's because you need a Pro license file to use the Wireless MPG.TRM wrote: ↑Sun Jan 16, 2022 2:24 pm I fund the issue. The wizard Is changing it's self back to NO MPG.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
ALWAYS, ALWAYS, ALWAYS Post a fresh report when asking for help.
We can take a look at the settings and give you suggestions.
