How to setup this tool?? MAX TOOL VFRR-6M093 (Answered)
ecdez
Post by ecdez »
Using in a gang tool setup on a lathe.
While this tool is shaped like a parting tool it's used like a turning tool.
I saw the setup instructions in the manual for both and there's where the confusion starts.
If I set it up like a parting tool in absolute mode there's no way to account for the width. If I put it in incremental mode does it account for the radius on both sides?
If I set it up like a turning tool there's no tool shaped like that in the "tool type" and so the geometry is likely going to be off.
Does it have to be setup as a custom tool?
The ones I have are
W = 0.093
R = 0.046
Just trying to go the easiest and most accurate way about it.
Thanks in advance!
Re: How to setup this tool?? MAX TOOL VFRR-6M093
Intercon will not handle that tool. I use some like that from Sandvik and you have to program the trailing edge toolpath yourself.
ecdez
Post by ecdez »
Well,... crap.
Thanks for the quick response though :D
