proma 150 THC
KevinTaylor
proma 150 THC
Post by KevinTaylor »
Which proma 150 torch height control do I need with the acorn?
The proma 150 or
proma 150 SD?
I know that 4.14 was just released and should work with the THC and that the actual plugin wont be until 4.16 but I am building now, and have no problem waiting patiently for 4.16 version as I am set on using acorn for my plasma table build.
Thank you
Shoptask turnado lathe converted to acorn (when I finally receive the machine)
Plasma table build with acron
Re: proma 150 THC
Three Plasma methods
these first two work with cnc12 now as they are independant systems
1.) THC that is Fully Independent of the CNC, uses its own additional Z axis and axis motor to move the torch head up and down. No special Acorn Plasma Plug in is needed for this type of THC.
2.) THC that is Integrated to CNC style 1: and hijacks the step and direction signals from the Acorn to the axis motor driver and adds and subtracts pulses as necessay. No special Acorn Plasma Plug in is needed for this type of THC. http://proma-elektronika.com/index.php/ ... act-thc-sd
this last method needs future CNC12 software support to work..
3.) THC that is Integrated to CNC style 2 : THC has three outputs UP, DOWN, and ARC OK. These Outputs are connected to the Acorn Inputs. Acorn Wizard as these selections in the input drop down list. ThcUp, ThcDown, ThsArcOk. The THC sends theser ‘commands’ to the Acorn by closing the input, when the UP input is closed CNC12 Adds steps to the Z axis position, when the ThcDown input is closed CNC12 Subtracts steps to the Z axis position. CNC12 waits for ThcArcOK before moving XY commands, when the ThcArcOK input is closed CNC12 knows that it is good to continue with XY movements.
http://proma-elektronika.com/index.php/ ... ct-thc-150
Retribution
Re: proma 150 THC
Post by Retribution »
May I ask when do you anticipate the release of version 4.16? I'm sure it's in another post but I couldn't find it.
"Life should NOT be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride!'" - Hunter S. Thompson
Re: proma 150 THC
Acorn CNC12 road map...(subject to change)
4.18 Maintenance release. has new Update Wizard so you don't have to type in all the config values.
4.20 Ether 1616 support
4.2x Maintenance release.
4.2x User editable VCP and Router version of CNC12
4.2x Plasma plug in
we are switching to faster lighter releases, each feature release will focus on one or two major items and about 20-30 little items. unlike the 4.12 to 4.14 release which had over 300 items.
Retribution
Re: proma 150 THC
I'm sorry, I thought I read somewhere 4.16 was going to be the Plasma plugin release?? Anyway, when do you think the Plasma plugin (4.26) will be released (ballpark)? Next few months? By the end of this year? Next year? I've already ordered the THC 150.
mario.morosavljevic
CNC Control System Serial Number: 38D2693E829E-0110180509
Re: proma 150 THC
Post by mario.morosavljevic »
I wonder as well how long will it take for 4.26.
We bought proma 150 back when we were using mach3, but seems like proma thc-sd is a way to go on if you're in a hurry.
citterly
Re: proma 150 THC
Post by citterly »
cnckeith wrote: Fri Apr 26, 2019 9:58 am Acorn CNC12 road map...(subject to change)
4.12 Ether 1616 support
4.20 Maintenance release.
4.2x Plasma plug in
Hi Keith - If I'm understanding this correctly, all the functionality to enable "advanced THC use" will only include changes on the CNC12 side?
Meaning there will be no hardware changes to Acorn?
I have a DIY CNC router, Marlin controlled, that I plan to implement Acorn once the Plasma Plugin is finished.
That means I could actually get it all running in terms of motion while the software is in DEV?
Chris
First Acorn project, proLIGHT 1000 mini mill:
viewtopic.php?f=60&t=1858
Re: proma 150 THC
citterly wrote: Tue May 14, 2019 1:09 pm
4.2x Plasma plug in
Meaning there will be no hardware changes to Acorn? << yes.. no hardware changes need for THC use>>>
That means I could actually get it all running in terms of motion while the software is in DEV? << absolutely>>
Chris
Re: proma 150 THC
Please see this post for follow up on plasma development.
viewtopic.php?f=60&t=2071&p=25704#p25704
