Software problem
Software problem
When I press cycle starts everything is cleared and press cycle start appears again.
https://youtu.be/7TedeUdYK1I
Using Geckodrive G540
Re: Software problem
Include a report and screen snips showing your wizard settings. Page 1 for sure. Also include a snip of your IO live (Press Alt + I)
Or simply scroll up on the message box and see what is still triggered
Here are photos. Will send backup at a later date when I find it.
- report_f045da76bcca-0102191506_2019-04-06_17-33-46.zip
- (200.68 KiB) Downloaded 108 times
You must have an estop configured. Even if it doesn't exist and is set to NO
Ok
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Machine doesn’t run at this time.
Watched and set controller as per Bench Test Running Motor.
Dose estop have to be wired to acorn to make light on G540 to change to green?
No change in software problem.
- report_f045da76bcca-0102191506_2019-04-07_11-53-38.zip
- (200.19 KiB) Downloaded 100 times
Kutton,
why are you using CNC12 version 4.12 and not the new version 4.14 if you start with a new system?
Your EstopOk is configured as NC (normally closed). So if you don't have an Estop wired the system remains in Estop status. You have to set it to NO if you don't have an Estop wired, otherwise nothing will work.
Also your ProbeDetect signal is configured as NO (normally open) which doesn't make any sense. Remove all probing stuff on your inputs until you have your motors running properly.
-swissi
-swissi
Download new version however wizard did not load.
