4th axis rotary table help <answered>
Swarfmonger
CNC Control System Serial Number: 74E1828900E1-1019181259
Post by Swarfmonger »
Hello,
I was trying to sort out one last thing on my CNC mill conversion and was wondering if someone could possibly help me. When I originally hooked up my 4th axis rotary table and tried it with the default overall turns ratio setting in the wizard of 5,it rotated 40 complete revolutions before stopping. Then I inputted .125 (5 divided by 40) and that made it read properly but now it is extremely slow. Is there something I can do to to speed things up a bit while maintaining a proper reading and function? Thank you very much!
Best regards,
Dave
report_74E1828900E1-1019181259_2019-03-26_07-21-34.zip
(186.85 KiB) Downloaded 91 times
Gary Campbell
Re: 4th axis rotary table help
Post by Gary Campbell »
Setting seps per rev and revs per inch is a straightforward numerical item if you post your driver settings and the reduction of the rotary fixture. Please post them
cnc_smith
Post by cnc_smith »
Swarfmonger wrote: Tue Mar 26, 2019 9:29 am Hello,
Best regards,
Dave
For a 4th axis rotary table the Slow Jog, Fast Jog and Max Rate are in degrees per minute not inches per minute. This is a common mistake when setting up a rotary table. Your Slow Jog, Fast Jog and Max Rate are 50 so this would be 50 degrees per minute. For rule of thumb for a rotary table if you use about 80% of the max rate this should not get you position errors.
Dana
Swarfmonger
I just clocked it and it is indeed doing 50 degrees per minute. I guess it just seemed slow when compared to the table and quill jog rates. Thank you both for your help,I really appreciate it!
