ACORN + SLO-SYN 2000 D6 DRIVE--video
pulsenpal
Post by pulsenpal »
the Centroid team was correct--the 24 vdc jumper was required to connect to header H4 for
proper step/direction logic output
but--the slo-syn drive 2000 d6 requires +5vdc to opto-isolator for enable function--so
a separate 5 vdc power supply is required for this function--this problem solved by arrival of meanwell
dual power supply 5/24 vdc
this system installs into romi lathe--with heidenhain rotary encoders on step motors
these will be connected to anilam dro --
in addition-handwheels with heidenhain encoders acting as pulse generators will be incorporated into
control options--I use reed relays to isolate multiple signal inputs when this level of complexity is required
it allows manual control of machine even if computer and acorn board are off--
cannot execute threading with this setup--but many manual functions are possible with complete bypass of
pics and video of this setup to follow
todays video is bench test with new power supply v2=+24vdc v1=+5vdc brown jumper connected to
opto-isolator on 2000 d6 drive ==+5vdc
https://www.youtube.com/watch?v=IzKHaTQ ... e=youtu.be
https://youtu.be/IzKHaTQDu4c
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Re: ACORN + SLO-SYN 2000 D6 DRIVE--video
Post by cncman172 »
Good Job, now you are cooking with Gas. :)
Russ
