As the subject states, Z homes fine, Y homes fine then X trips the home switch and keeps going till the limit stops it.
I did a clean install of windows 10 on my cnc pc and updated CNC12 from 5.08 to 5.30 while I was at it. Re-entered the wizard settings and copied in my previously working cncm.hom file and started encountering this issue. X,Y,Z are connected to a single "home all" input so I can't understand why Z and Y work but X doesn't. I ran the home program in single block with the homing speed lowered to 1.0 ipm and can clearly see the home switch trip well before the limit, which I measured at 0.170" separation. What am I missing here?
X axis trips the home and keeps going to the limit <Resolved>
- report_5445380390DB-0104247810_2025-08-09_11-14-53.zip
- (1022.38 KiB) Downloaded 3 times
Re: X axis trips the home and keeps going to the limit
From your cncm.hom:
From your report file:
You are trying to home X in the plus direction, but you have only designated a home switch input for X minus.
M92/X L1 ;Move Plus to Home Switch
Axis Label Motor Encoder Lash Comp. Limit Home Dir Screw
revs/in counts/rev. (inches) - + - + Rev Comp
1 X 10.1605000000000008 10000 0.0002 2 2 1 0 Y N
2 Y 10.1605000000000008 10000 0.0015 2 2 0 1 Y N
3 Z 10.1605000000000008 10000 0.0000 2 2 0 1 Y N
1 user liked this post
I knew it had to be something simple I was missing! Thanks!
