Somethings going wrong with cut speed.
Moderators: cnckeith, Joey
AWFAB
Post by AWFAB »
I line up a few simple parts and the fist one cuts great at 34 imp on 3/8 steel same with the second hole but then for some reason the next cut shifts down the speed almost to 2 ipm also my jog speed is so low its worthless. Now I havent touched anything when this happens just does it automatically.
The only way I know of right now to get my jog speed and my cut speed back is to close out and power cycle the board. Kind of worried because this is the 5 time its happened since cutting. Im stuck in the middle of a job because I dont know how to start the job in the middle, I can start over again and just waste some steel I guess.
Joey
Plasma/Laser Lead
Re: Somethings going wrong with cut speed.
Post by Joey »
Please Post a Fresh Report and the G-code please.
Is the Feed rate Override at %100 percent on the VCP?
Are you running the CNC12 version 5.3 software? If not I would update to the latest rev for sure.
Here is a walk through video of the Latest 5.3 version of restart mode.
