DM-3000 Lathe Acorn conversion
kaimaui
Post by kaimaui »
Here is a link to some photos for the acorn Lathe conversion I am working on.
I will organize a little better as I get further along.
KAI
kaimaui
Re: DM-300 Acorn conversion
Post by kaimaui »
Fastest1
Post by Fastest1 »
I have one of those and it is next.
Do you plan on using the turret bidirectionally?
It is just a matter of activating that electromagnet.
I had it working in Mach but rotating one direction and then backing up onto the pawl.
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
kaimaui
Re: DM-3000 Lathe Acorn conversion
Post by kaimaui »
In discussions as to the best way to do that. No fixed decision yet.
Right now The simpler the better.
Fastest1
Post by Fastest1 »
The easiest way would be to rotate 63 degrees or so and back up against the pawl.
However the Acorn is most likely capable of the control of the electromagnet (it is 24v IIRC) and use the switches in the turret for tool position verification.
Leadshine MX 3660
Fastest1 wrote: Wed Nov 15, 2017 7:13 pm The easiest way would be to rotate 63 degrees or so and back up against the pawl.
Yes, Acorn can do it, use an output to pull the electromagnetic pawl, then rotate as you say. Its a matter of programming the PLC. There are at least 3 if not 4 of us with the same machine....they are popular little buggers and heavy as sin.
KAI you've done a nice job on the conversion so far. Great work!
kaimaui
Post by kaimaui »
Just got done installing the AC motor and drive.
I still have to Connect the drive to acorn.
Updated photos are at the bottom of the google photos album.
I ended up mounting the spindle motor underneath as it was bigger then the existing motor and would have made the footprint of the lathe bigger.
KAI
Looks good Kai. Maybe you'll have the spindle under Acorn control soon.
DICKEYBIRD
Post by DICKEYBIRD »
martyscncgarage wrote: Thu Nov 30, 2017 8:25 am Looks good Kai. Maybe you'll have the spindle under Acorn control soon.
...and don't forget the KBSI-240D isolator board between the Acorn & your KBPC-240D. We don't need any sudden releasing of the magic smoke! :shock:
Milton in Collierville, TN
He went with an AC motor and VFD
