I have a DC drive KBMG-212d with isolation board for analog.
The way this drive functions is:
1. enable on
2. 0-10v+ signal on SIG terminal on the isolation board and motor goes forward
3. reverse the 0-10v polarity on SIG terminal and it runs in reverse.
So #1 and an analog goes forward. #1 and #3 plus analog goes reverse
My thoughts are:
1. connect Acorn relay 1 to short the enable pins for motor drive
2. nothing needs to be done to go forward except send an analog voltage to SIG
3. connect Acorn "spin reverse" output to a DPDT relay to swap the polarity of the analog signal
So my questions are: Where are the PLC controls to address the outputs so the G/M codes operate the motor properly and, how do you handle the spin forward if no "spin forward" signal is necessary for the drive without wasting a PLC output?
Hope that makes sense...
Clay
DC drive with reversing control/relay question
Clay
near Winston-Salem, NC
Re: DC drive with reversing control/relay question
Folks that know this stuff will probably want the manual to answer so I posted it for you.
I just rigged my KBCC over the weekend but it's an older design. I just used the two Acorn relays to short the "S2" terminal to "S1" or "S3" for CW/CCW. I'll use the external relay module later for cutting oil, etc. Just want to run the spindle for now.
- kbmg_manual.pdf
- (3.43 MiB) Downloaded 141 times
Milton in Collierville, TN
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
This Dilemma is why I asked Centroid to consider using +/- 0-10VDC Spindle control on a future hardware revision of Acorn. Just like OAK and ALL IN ONE DC.
Clay, I think you are on the right track.
Use another relay to open and close the enable circuit? Use the SPINDLE BRAKE RELEASE output to control it from Acorn. It should toggle on and off no matter which direction you are rollling. So your DPDT relay would be on output Spindle Reverse, as you mentioned, its already in forward in the normal state. You have to use the DPDT because the state must change together so you don't short Acorn's Analog outputs.
Since one of the relays on Acorn is NO, and you use your enable circuit on say Relay 2, program relay 2 as SPINDLE BRAKE RELEASE. It will close when you call for M3 or M5 (in theory). (If I read correctly the KB drive must have its enable circuit closed for it to operate)
Think this suggestion through before testing. I don't wanna be responsible for magic smoke rolling!
Sketch attached for a visual representation (Enable circuit not shown)
Good discussion...
Let's see if Scott or Keith concurs or has a better idea.....until they add the -/+ 0-10VDC feature to Acorn.
Good discussion...
Thanks Marty!martyscncgarage wrote: ↑Thu Nov 02, 2017 2:54 pm This Dilemma is why I asked Centroid to consider using +/- 0-10VDC Spindle control on a future hardware revision of Acorn. Just like OAK and ALL IN ONE DC.![]()
Think this suggestion through before testing. I don't wanna be responsible for magic smoke rolling!![]()
Good discussion...
Let's see if Scott or Keith concurs or has a better idea.....until they add the -/+ 0-10VDC feature to Acorn.![]()
I actually meant to say "brake release". Good catch.
Your circuit is almost exactly how I wired it! The smoke is not magic... That's a mist.
One other thing I would really like to understand is how do you control the outputs/relays in the G/M code
Clay
M3 S1000= Spindle forward, turn 1000rpm
M4 S2000= Spindle reverse, turn 2000rpm
Once the spindle is running in the desired direction you can change the speed with the "S" word until:
M5=Spindle Off
Is that what you wanted to know?
Did you try the circuit and use the spindle brake release?
Pictures damnit! If I have to post videos, you guys gotta too!
M5=Spindle Off
LOL, everything is still on the bench for wiring. I only have about a half hour per day to mess with it right now.
I haven't tested it with the acorn yet.
As to the code, I understand the m, s, in the program file. I was trying to understand how m3 m4 m5 addresses the board output. I was assuming the "spindle reverse" in the acorn configuration program was tied to m4, but I didn't see anything that confirmed this.
For example if I change output 6 to "spin Reverse" does M4 now control that output?
I'll snap a photo tonight, but there ain't much to see.
Clay
Yes, as whichever output you use for spindle reverse will be controlled with M4, or the reverse button on VCP.frijoli wrote: ↑Fri Nov 03, 2017 6:00 am LOL, everything is still on the bench for wiring. I only have about a half hour per day to mess with it right now.
I'll snap a photo tonight, but there ain't much to see.![]()
Test it for yourself with a meter. Set to DC, red lead to 24VDC on power supply, black lead to the assigned output. Off should be zero or near zero volts and on should show 24vdc.
You can also test analog spindle output and your relay rig this way. Without connecting to KB drive. But you must set min and max spindle speed in the Wizard first. Then call S words from min to max speeds and watch your meter.
