spindle wiring Delta VFD
Posted: Mon Jun 10, 2024 5:56 pm
by schernutan
Not sure if my wiring is correct. I'd appreciate if you can look at it and advise. This is on a PM940 Mill. All my axis' are working. Home and limit switches set-up. Attached report file and photos. First time posting. Thanks for your help.
Re: spindle wiring Delta VFD
Posted: Tue Jun 18, 2024 2:06 pm
i moved this post into the acorn forum
Posted: Thu Jun 20, 2024 9:08 am
by Fordmasterkw
If you post what vfd your using and or a diagram of it will help.
Your second image of the relay board looks like it is missing a common??
Not sure what you have?
I have a pm940v with a GS10 drive and my relay board wiring is different than what you have there in the image.
Again, post what you have and what wiring diagrams you used.
