spindle wiring Delta VFD
schernutan
CNC Control System Serial Number: E06234471BC2-03212408100
Post by schernutan »
Not sure if my wiring is correct. I'd appreciate if you can look at it and advise. This is on a PM940 Mill. All my axis' are working. Home and limit switches set-up. Attached report file and photos. First time posting. Thanks for your help.
report_0035FF621168-1202204167_2021-12-27_13-05-24.zip
(606.52 KiB) Not downloaded yet
Re: spindle wiring Delta VFD
i moved this post into the acorn forum
Fordmasterkw
CNC Control System Serial Number: 0626181997
Post by Fordmasterkw »
If you post what vfd your using and or a diagram of it will help.
Your second image of the relay board looks like it is missing a common??
Not sure what you have?
I have a pm940v with a GS10 drive and my relay board wiring is different than what you have there in the image.
Again, post what you have and what wiring diagrams you used.
