C-Axis for lathe (construction in progress)
Black Forest
Re: C-Axis for lathe (construction in progress)
Post by Black Forest »
Very nice job.
Scary
CNC Control System Serial Number: None
Post by Scary »
That looks awesome. How are you programming the live tooling? Are you using cnct or cncm
Scary wrote: Sun Jul 17, 2022 3:50 am That looks awesome. How are you programming the live tooling? Are you using cnct or cncm
cnct since it is a lathe :)
I have made an easy to use program that can be used with live tooling or fixed tools for broaching or milling linear grooves...
GrooveBroaching.cnc
(1.74 KiB) Downloaded 45 times
Reedfirst
Post by Reedfirst »
Wow! Great work!
Same G-Code works for Keyways also....
Muzzer
Post by Muzzer »
suntravel wrote: Sat Jul 16, 2022 11:48 am Now it works for first testing, but still waiting for the clutch....
Got this running today, but I will make some more complex things with it like shown here :mrgreen:
Nice work, Uwe. Perhaps one day I might tackle the PLC code like you but so far I have avoided it!
It's a tiny quibble but when testing the repeatability (video, 4:15), ideally you would approach the same set point alternately from each direction, as this will show you the backlash.
Muzzer wrote: Sun Jul 17, 2022 4:45 pm
yes you are right.
Resolution with 4.5:1 gearing and 4000 Steps is anyway limited to 0.2°. That is also the max. allowed backlash of the planetary gearbox I am using.
For a higher precision you must use a harmonic drive with higher ratio and no backlash, but this is also a lot more expensive.
The direct servo driven C-axes on my production machines have an 90000 line encoder for C, that gives 0.01° resolution, but they use a 7.5 kw servo for max. 30mm turning diameter on the small ones..... :mrgreen:
This here is only a hobby project on a tight budget ( ~700 bucks for everything needed )
sweet! nice work, thanks for posting.
Some engraving with the C-axis....
Muzzer
Post by Muzzer »
suntravel wrote: Mon Jul 18, 2022 1:05 am For a higher precision you must use a harmonic drive with higher ratio and no backlash, but this is also a lot more expensive.
I have a 50:1 harmonic drive on my 4th axis which is pretty much backlash free. You can get used ones from the Korean machine breakers for a reasonable price. If there is any backlash it will likely be due to the toothed belt drive, reduced by the 50:1 ratio. certainly I can't measure it with my test indicators.
If only my linear axes had such little backlash - there is a special disappointment that follows when you install Swissi's probe app and it tells you in cold hard numbers what is actually happening!
