Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Re: Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Here is error log.
Information: Configuration: CENTROID Milling Community 1.0
Information: Vendor: CENTROID
Information: Posting intermediate data to 'C:\Users\Cad Computer\Desktop\1001.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, April 22, 2025 7:13:43 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 5.245.0
Configuration path: C:/Users/Cad Computer/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/Centroid_Mill_Community_v1.0.cps
Security level: 1000
Include paths: C:/Users/Cad Computer/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Thursday, January 9, 2025 4:03:12 PM
Output path: C:\Users\Cad Computer\Desktop\1001.nc
Checksum of intermediate NC data: 5ed6fade358e4b01133b7d3dcf73a305
Checksum of configuration: f60260c71d2c6496ac8126f0f7c4014e
Vendor url: http://www.centroidcnc.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion CAM 2601.1.34
Warning: Work offset has not been specified. Using G54 as WCS.
Error: machineSimulation is not defined
Error at line: 2095 (Centroid_Mill_Community_v1.0.cps)
Error in operation: 'Multi-Axis Finishing1'
Failed while processing onRapid5D() for record 423.
Error: Failed to execute configuration.
Stop time: Tuesday, April 22, 2025 7:13:43 PM
Post processing failed.
You did not setup a machine for simulation with the kinematic of your machine
This post is using the kinematics from the simulation machine with more than 3 axis.
I get this error if i set up a machine for config just trying to simulate it in fusion.
Cannot simulate with machine:
Machine configuration is overridden by the post script.
at onOpen (Centroid_Mill_Community_v1.0.cps:468)
ok no matter what i put inside the machine configuration, i get an error just trying to simulate with the swissi original post processor and the community one.
here is the swissi original one error log.
at onOpen (Centroid_Mill_MinRev-40783-swissi-005.2 + Spikee machine sim mod + uwe peck tapping mod.cps:468)
 In-process stock is missing. Stock might be inaccurate
can you upload the fusion files, so I test it out?
yes. but 3 axis centroid post processor from fusion works with machine simulation. So it has to be something in both of these post processors.
- Test part 4th axis.zip
- (6.53 MiB) Downloaded 89 times
Should work now.
I have added Inverse time.
- centroidForumV2.zip
- (20.06 KiB) Downloaded 50 times
1 user liked this post
this same file download on page 1?
I get this error now when trying to simulate 4 axis.
Error: Section.getInitialToolAxisABC() is not allowed for section.
Error at line: 847 (Centroid_Mill_Community_v1.0.cps)
also get this when trying to post an opp.
Start time: Friday, April 25, 2025 6:16:01 PM
Configuration path: C:/Users/Cad Computer/AppData/Local/Autodesk/Autodesk Fusion 360/HXKFJYDRGFDW/W.login/M2/us-D20200828327366981/CAMPosts/Centroid_Mill_Community_v1.0.cps
Include paths: C:/Users/Cad Computer/AppData/Local/Autodesk/Autodesk Fusion 360/HXKFJYDRGFDW/W.login/M2/us-D20200828327366981/CAMPosts
Checksum of intermediate NC data: be40c86b8d89ffccad8cc76a6292d820
Failed while processing onRapid5D() for record 425.
Stop time: Friday, April 25, 2025 6:16:01 PM
