Weird Things <resolved, recalibrated Z axis servo>
I was cutting a gear when something went wrong. The first gear, pictured on the right went fine. The second gear started cutting adifferent pattern. Any thoughts. Thanks
- report_E415F6F250EF-0205202948_2024-12-15_13-22-37.zip
- (1022.76 KiB) Downloaded 5 times
- CNC Control System Serial Number: F045DA78F172-1129181385
Re: Weird Things
Looks like lost steps.
Maybe started in your Z axis there, then causing X or Y to lose steps when it dragged across the workpiece due to the lost steps in Z?
Are you plunging too fast with Z?
All speculation without more info.
Re: Weird Things
Recalibrated the z axis servo and the issue seems to be resolved.
Re: Weird Things <resolved, recalibrated Z axis servo>
thanks for reporting back. what did you do exactly to resolve?
