Tool Library Description lengths seem to be limited < Mill and Router CNC12 Tool Library redesign >
Re: Tool Library Description lengths seem to be limited
Yes CHIPS can import that...
Your Image is looking good, but not Tool Diameter?
corbin
CNC Control System Serial Number: 3484E42757Cd-1018248693
Post by corbin »
suntravel wrote: Sun Nov 17, 2024 10:45 am Yes CHIPS can import that...
Not yet! First pass is to just allow assignment of pockets to a particular tool number. Second pass will be a complete tool table, on a separate tab.
The Centroid API is pretty simple and easy to work with, so it won't be hard!
Corbin
If you what you are doing everything is simple, but not for everyone :lol:
I seldom know really what I am doing if it comes to coding ;)
corbin wrote: Sat Nov 16, 2024 9:29 pm
grossmsj wrote: Sat Nov 16, 2024 11:37 am CHIPS is the way to go. For sure.
I'd be interested to see how it works on the EX controller.
Yeah, the Avid CNC Ex controller, right? I got mine a week ago, and I wanted to setup my ATC with it. The default macros wouldn't work for a proper tool changer, so I started writing my own. I also wrote an app to manage the tool library, in particular what tool is in what "pocket/bin" for an abstract mapping on a regular tool rack.
Attached is a quick image of what I have so far, but I was just thinking about skinning it to match CNC12, similar to what CHIPs looks like they are doing.
Corbin,
Nice work, this is why we created the Centroid APi! putting the power in our customers hands!
Please make a post in the new Centroid APi forum and tell us more about your app! -Keith
draft CNC12 Mill and Router Tool Library for comments and suggestions.
look for latest pdf further down the thread!
avp
CNC Control System Serial Number: E062346A1C67-0716214939
Post by avp »
Looking good, liking the auto/manual option!
Coolant and max. rpm for Intercon is skipped?
grossmsj
Post by grossmsj »
I like it!
I really like the consideration and provision for diode laser as a tool. A couple of questions in that regard:
1) Will that particular tool number be set, much as #10 is for a probe?
2) The offset for the laser caught my attention. I really like that. Which leads to my last question.
3) Consider that some of us use multiple laser heads (I have three). I don't know how to handle that, but it might be worth considering in the design phase.
-Scott
Now would probably be a good time to research the different types of drill banks and panel saws found on production router tables.
There will usually be an XY offset.
Drill banks may or may not have a solenoid output for 90-degree rotation (align with X or align with Y).
Drill banks may be all-or-none, or may have individually-selectable drills.
A panel saw may or may not have a solenoid output for 90-degree rotation.
There are probably lots of other variations that I have not yet encountered....
Or Diameter setting with Renishaw TS27 or Laser like often used on professional VMCs....
