FRV - Feed Rate Variation New Function <FRV and SSV are now standard features of CNC12 v5.2+ >
Re: FRV - Feed Rate Variation New Function
This Thread is outdated, Beta 5.19R9 is already with FRV and SSV professional made from Centroid with smooth sine curves.
thanks for reporting back, making the suggestions and your contribution to the development and testing! FRV and SSV are now standard features of CNC12 with the upcoming CNC12 v5.2 release! (Free of charge.)
Re: FRV - Feed Rate Variation New Function <FRV and SSV are now standard features of CNC12 w/ upcoming CNC12 v5.2 >
SSV is a very useful feature for lathes.
In this example tool steel with HRC35 turned down from 20 to 18.2mm with 2000rpm f 0.12mm ap 0.2mm on 280mm length with no chatter and less than 0.001mm deviation on a cheap Chinese lathe.
SSV +-100 rpm / 1.5s no chatter ok surface finish
I am really happy with the perfect implementation of this feature from Chris.
Finished part is a spindle for a drilling machine.
CNC12 v5.20 with SSV and FRV as a standard feature is now available for free download.
Hey Uwe.
Can you tinker a bit with the SSV and FRV?
SSV actually works quite well.
Can you please ensure that SSV is automatically switched off when a program is stopped?
This also applies to the emergency stop
The same problem and with FRV it really is a problem also applies to FRV.
My machine rattles to the starting point.....disaster
What would also be good if you could find a real M command to activate and deactivate it.
This M..../....
disaster
I would have an improvement for FRV
For plastic to break chips, FRV as it is now is not good enough.
For aluminium/steel/Va is great but plastic..... I've tested it
Can you integrate feed hold variation into the PLC?
I thought that with Feed Hold Variation activated you could always have the machine stop automatically for 0.5 seconds. Let's say every 2mm or so...
Or let's say in the menu you can specify how many mm it should stop for so many 0.5 seconds
Again in German because Google German is not real German...
Hey Uwe
Kannst du mal bitte noch bisschen An SSV und FRV rumschrauben?
SSV funktioniert echt gut.....Das war ja Klar.....
Kriegst du es hin das SSV und FRV stoppen wenn man das Programm anhält oder Notaus drückt?
Beim FRV ist es Sau nervig die Maschine rattert beim Neustarten im FRV Modus zum Startpunkt.
Was gut wäre wenn du FRV und SSV einen eigenen M Befehl zum starten und stoppen geben kannst.
Die M Befehle mit dem zwischen Strich sind einfach Mist.....Hey du bist doch ein Profi....das kannst doch keinem verkaufen...
FRV arbeitet für Alu Stahl und VA echt super....aber eh für Plastik muss die Maschine anhalten....
Daher stelle Ich mal die Frage:
Kannst du nicht aus FRV FHV (Feed Hold Variation) machen?
Sagen wir alle 2mm stoppt die Maschine für 0.5 Sekunden......
Dann können die Späne richtig brechen.....
Kapiert?
Stephan
This M..../....
disaster
Hey Uwe
Kapiert?
Stephan
Hi Stephan,
this is all possible right now, you can also have different FRV and SSV for each cut if you write the g-code this way.
If I have time for this, I will write a manual with examples.
1 user liked this post
I have been waiting patiently for this feature and I am so very happy to see it is available. I am not very good with PLC, but I would like to use the SSV specifically. Is there a manual or anything for implementation? Also, is there a way to activate this feature in post processing with Fusion 360?
Thanks!!!
Andy
Thanks!!!
Andy
with Manual NC Entry you can turn FRV on and offScullMFG wrote: ↑Tue Feb 11, 2025 11:05 pm I have been waiting patiently for this feature and I am so very happy to see it is available. I am not very good with PLC, but I would like to use the SSV specifically. Is there a manual or anything for implementation? Also, is there a way to activate this feature in post processing with Fusion 360?
Thanks!!!
Andy
https://help.autodesk.com/view/fusion36 ... BCC5EF4439
Insert M94/71 g code to turn FRV On
and to turn it off maybe for the next tool
insert M95/71
SSV to avoid vibration turning a thin wall on cylinder liners:
Really great that this option is included in CNC12.
