Parameter 16 is the max. probing distance. Set this to 300 (mm) on a metric system
ProbeApp V3: The Ultimate Probe Software for CNC12
Re: ProbeApp V3: The Ultimate Probe Software for CNC12
- CNC Control System Serial Number: 544538046067-0616237327
I've only just begun using it. Loving it so far.
- CNC Control System Serial Number: 0008DC111213-0116230085
oh, thx UweParameter 16 is the max. probing distance. Set this to 300 (mm) on a metric system
edit: solved: 16 was set to 254
I'm getting ready to install 5.10 of CNC12 and notice where it has a warning about all third party apps must be 64 bit. Does this impact using ProbeApp? Thanks.
ProbeApp will work with 5.10
- CNC Control System Serial Number: 544538045567-0616237311
Is this App still available? The links don't get me to any download options.
David
David
E415F6F70BC3-0318203049
Swissi has replaced ProbeApp with CHIPS which takes ProbeApp to far more advanced level.
Full CHIPS details here viewtopic.php?f=60&t=10245
Hope this helps
Nigel
Nigel
