MDI Spindle input not working (Error code: 5038) <resolved>
rnc
Post by rnc »
Hey guys,
this is almost too embarrassing, but i cant get it to work. I've just upgraded my spindle to a water-cooled one. Set the parameters accordingly in the VFD (the cheap Huanyang one) and the wizard.
Now i can run the spindle in manual mode no problem.
In manual mode i get a warning telling me the spindle speed is lower than the input command (5038: specified spin speed < min spin speed). Nevertheless the spindle runs perfectly fine and i can up/down the rpm without fuzz.
But using the MDI to set spindle speed does nothing.
Likely i set something wrong, but for the love of me i cant figure it out!
Any ideas?
Raph.
dpascucci_support
Re: MDI Spindle input not working (Error code: 5038)
Post by dpascucci_support »
Please post a fresh zip report and a pdf of your wizard config (ctrl+p on any page in the wizard).
Domenic
Ken Rychlik
Post by Ken Rychlik »
try giving it a speed with the m3 in the mdi. (m3 s12000) or whatever rpm you want it to run. Report or screen shots of your spindle wizard info would help.
Ken
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
Go back into the Wizard and check your spindle speeds. You cannot run at less than the minimum entered here. Put simply, the system will always default to this minimum where you enter a lower speed
Hope this helps
Nigel
rnc
Post by rnc »
Oh well. I fixed it. Thanks for the suggestions but i couldn't narrow it down. I reset the whole system and reconfigured the VFD. Now everything runs smoothly.
Thanks anyways. Always really glad to know there is a crowd out there being as helpful as you are.
Cheers and have a wonderful weekend. I have some chips to cut! - at last.
Raph.
