Inches to metric
Moderators: cnckeith, Joey
ftraube@gmail.com
CNC Control System Serial Number: 6844
Inches to metric
Post by ftraube@gmail.com »
How do I change CNC12 from inches to metric?
All my drawings and everything we cut is metric
Re: Inches to metric
Setup / Config / Contrl
ftraube@gmail.com
Thanks for your reply
Config asks for a password. I type 000, Says Limited access.
Then I can see inches/metric, but not allowed to modify.
I have PRO, License activated.
How do I setup or request the Password?
checked all documentation, no reference to that password
avp
CNC Control System Serial Number: E062346A1C67-0716214939
Post by avp »
Default password is 137
Sword
Post by Sword »
Disable it in the wizard at Preferences/CNC Control, first option top of the page.
Scott
ftraube@gmail.com
Password worked, I was able to change to mm.
Thanks for your help
ftraube@gmail.com wrote: Tue Mar 28, 2023 12:49 pm Password worked, I was able to change to mm.
be sure to change both "machine units" and "DRO display units" to Millimeters. shut down, reboot, re home out to be safe.
Once you get to the configuration screen, you actually change between inch and mm by hitting the spacebar. Change both as Keith said.
ftraube@gmail.com
Got it. Thanks for the advise
