starting in wrong position X <resolved>
mikechung
Post by mikechung »
I have generated in Fusion 360 Gcode.
I have noticed even thought I have set home, setup part size, tool positions, Sample Pawn m works fine
In the code it shows starting at X22.2
The part is 22mm diameter, should the position be X11.1.
When I run the code the starting position is X22.2
Can you advise what I am doing wrong?
Attached code , jpeg picture, report
Mike Chung
https://www.vertogen.eu
N21 G0 X22.2 Z3. T0404
N22 G1 Z1.125 F0.127
N23 X21.5
N24 Z-23.794
N25 X22.
report_E415F6F16C71-1124204084_2022-12-26_19-03-16.zip
(678.74 KiB) Downloaded 4 times
1001_mushroom.cnc
(7.35 KiB) Downloaded 1 time
Re: starting in wrong position X
Machine parameter 55 controls whether your DRO displays in Radius or Diameter mode. Yours is set to 0 to display diameters (in my opinion that's the best way).
X positions are not only displayed as diameters on the DRO; they are interpreted as diameters from the G code.
Therefore, with P55 = 0 (as it should be), "G0 X22.2" will move the X axis until the tool tip is 11.1mm away from centerline, and the DRO will show X at 22.200.
If you have your machine set up so that the X axis moves 22mm of actual distance, between the place where the DRO shows "X0" and the place where the DRO shows "X22", then your X axis mm/rev value is wrong, and needs to be changed from 0.8 to 1.6 (to match Z).
mikechung
Post by mikechung »
Hi
From your comments I rechecked the Revolution per Travel on the X axis.
On the Wizard configuration mine was set to .05 , I tried 1.00 and now the starting position is correct.
Mike
