Grove and cut off tool question
Re: Grove and cut off tool question
vw_chuck wrote: Fri Sep 02, 2022 9:04 am I know on my lathe which is a 11x26 it doesn't even have any gibs on the Z axis. You can lift the whole carriage up if you are strong enough. Kind of crazy.
You can and should fix this, needs only some milling and scraping ;)
https://centroidcncforum.com/viewtopic.php?f=60&t=6963
BillB
Post by BillB »
I do know that tool is the most usefull tool I own. The clamp down one can be used for grooving, turning, profiling pretty much anything in aluminum. They work great and you can get like a pack of 10 inserts on amazon for like 10 bucks. You really can't beat it.
Ya I see the versatility in them as well. Just wonder how much side load they can take?
BillB wrote: Fri Sep 02, 2022 4:03 pm
Look here for cutting parameters groove turning:
https://www.iscar.com/eCatalog/Family.a ... &pID=&cID=
These are inserts made to turn aluminum.
