Help please. No Vcp on cnc 12 start up
Moderators: cnckeith, Joey
rollinschris61
Plasma CNC Controller: Yes
Post by rollinschris61 »
I used my acorn powered plasma table last night and everything worked fine. I went to you use it this evening and the vcp panel won’t come on, it just shows a blank screen. Any help would be much appreciated.
Re: Help please. No Vcp on cnc 12 start up
looks like windows minimized it?
reboot.
post pc info
post fresh report.zip so we can see your setup data
rollinschris61
Thanks for the reply keith. Heres the report att. If it is just minimized i cant seem to figure out how to get it back up. I have rebooted the computer multiple time.
Hers the pc info.
Device name plamsa
Processor Intel(R) Celeron(R) N4020 CPU @ 1.10GHz 1.10 GHz
Installed RAM 4.00 GB (3.83 GB usable)
Device ID F991F66E-188A-4D57-A770-BC0AE72DD7CE
Product ID 00331-20313-16287-AA290
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Pro
Version 21H2
Installed on ‎6/‎8/‎2022
OS build 22000.856
Experience Windows Feature Experience Pack 1000.22000.856.0
report_E0623479E814-0411225911_2022-08-23_19-17-07.zip
(2.5 MiB) Downloaded 20 times
Sorry to be the bearer of bad news but that PC does not even come close to meeting the minimum requirements to run CNC12. It has a single thread rating of 1168. You need a new PC that meets the requirements, here’s a link to those standards.
https://www.centroidcnc.com/cnc_pc_perf ... ments.html
rollinschris61
With all due respect it’s been running it great for months 🤷🏼‍♂️ Just happened all at once.
rollinschris61
Never mind guys, i didn’t figure it out but I did just back up my custom files and redownloaded cnc 12 and I’m back up and running. Thanks for the replies.
rollinschris61 wrote: Tue Aug 23, 2022 10:08 pm Never mind guys, i didn’t figure it out but I did just back up my custom files and redownloaded cnc 12 and I’m back up and running. Thanks for the replies.
ok. great. please update to v4.80 so we all are on the same version. https://www.centroidcnc.com/centroid_di ... loads.html
as far as CPU single thread bench mark if the CNCPC is not 1500 or higher....you will run into issues using Plasma Smoothing if you have a short vector G code program
Aurelien
CNC Control System Serial Number: 0035FF8D294B-0211225688
Post by Aurelien »
hello. I just updated to v4.80 and have the same problem. the VCP no longer appears.
I also just realized that all my tool data has disappeared... :evil: is there a way to recover them or do I have to redo them all?
slodat
Post by slodat »
This is the same problem I had..
rollinschris61
Yeah that really sucks. Mine was in a plasma cutter so I didn’t have any tool data to get lost but I just copied my plc files and deleted and reinstalled cnc12 and I was back up and running. It’s obviously some kinda strange glitch in the system.
