6040 Chinese routers
Plasma CNC Controller: Yes
Re: 6040 Chinese routers
lilb93 wrote: Mon Nov 20, 2017 11:03 am first one shows the 4 drivers and the power supply hidden under the VFD board. Last one is there VFD board. I have no manual with it or wiring schematics.
It appears doable.
You have 4 stepper drivers, you need to decipher the chinese marks on the terminals to determint which is step and direction.
The board with the capacitors appears to be a DC spindle drive.
Can you vary the speed of the spindle drive?
You can probably do some detective work with a meter and figure things out.
Do you have basic electronic/electrical skills?
lilb93
CNC Control System Serial Number: 0216041209
Post by lilb93 »
Yes I can wire almost everything , was going to order a new power supply, new cables since none are shielded. (That seems to be the main problem a lot of people talk about. Get a gecko 540 board. and get a true VFD. Then I think it would be an easy changeover and add hard limit switches to it also.
the side plat between the two towers on the X axis seem flimsy, so I removed the 1/16 tin plated and replaced it with 1/2" 6016 plate.
I have a CNC Shark Pro which is all plastic and it does cut wood really good, for being all plastic. I never tried aluminum on it. It did come with the full version of V-carve pro from Aspire. Which is real easy to use.
Barnesville, PA.
lilb93
Post by lilb93 »
Just looking on the V-carve Pro it gives me 3 Centroid posts. wondering which would you use with the Acorn.
Barnesville, PA.
lilb93 wrote: Mon Nov 20, 2017 1:15 pm Yes I can wire almost everything , was going to order a new power supply, new cables since none are shielded. (That seems to be the main problem a lot of people talk about. Get a gecko 540 board. and get a true VFD. Then I think it would be an easy changeover and add hard limit switches to it also.
The G540 is a great choice. Sounds like you have a plan.
Be sure to post photos as you go and a video when you are done with it!
