4th Axis?
n2xd
CNC Control System Serial Number: 0943
4th Axis?
Post by n2xd »
I am thinking of adding a 4th axis for gear cutting with my Acorn controlled mill. Anyone have any suggestions? Thanks.
John
briuz
Re: 4th Axis?
Post by briuz »
Without more information, we don't have much to go on.
For gears I'd use a stepper motor controlled rotary table with a tail stock. I have 4 inch tables for the Sherline mills and a 6 inch table for the Tormach. As long as the stepper motor driver has step and direction connections (most, if not all, do) then it should work.
Re: 4th Axis?
None of Centroids products will do gear hobbing yet. You can certainly use a 4th axis as a positioner when using a form cutter.
briuz
Re: 4th Axis?
Post by briuz »
Sounds like a feature request! :mrgreen:
tblough wrote: Fri Aug 27, 2021 1:48 pm None of Centroids products will do gear hobbing yet. You can certainly use a 4th axis as a positioner when using a form cutter.
