Acorn Version 4.08 CNC12 Mill and LATHE now available for download
New version (v4.08) of Acorn CNC12 is now available for both Mills and Lathes.
Download and Instructions are here.
http://www.centroidcnc.com/centroid_diy ... loads.html
DICKEYBIRD
Re: Acorn Version 4.08 CNC12 Mill and LATHE now available for download
Post by DICKEYBIRD »
Hi Keith, in case you didn't see it in the other thread, I can't get my Pro unlock to work with 4.08. It was emailed to me on Aug 18 but I never tried to use it until lathe came out. I have everything installed per your video and working fine but it still says "Acorn free." Will I need a new unlock for the 4.08?
Milton in Collierville, TN
4.06 Pro and Ultimate Licenses work with 4.08
maybe you got one that never worked since you didn't have a chance to try it.
Please post a report.zip file so we can generate you a new Pro License.
DICKEYBIRD
OK, will do. Probably tomorrow, I'm on grandkid workshop lock-down for today. The 7 yr. old girl is great. She quietly putters around the shop with scrap wood blocks & drawing on old papers. The 2 1/2 boy is a terrorist. He turns every wheel, flips every switch, turns over every liquid and asks a million times "What's this pappaw, what's this pappaw...." I finally had to give up & lock the door. Give him a few years though & he'll be building race cars & airplanes! :D
DICKEYBIRD
OK, the little sweethearts went back to Mom. :) Here's my report.zip file.
report_985DAD887BFB-0605170051_2017-10-22_17-43-19.zip
(166.93 KiB) Downloaded 169 times
Acorn Lathe Pro License for Acorn #985DAD887BFB-0605170051 attached.
after downloading...please rename the file from a .txt to a .dat extension before importing with the Utility menu as per this post.
viewtopic.php?f=60&t=944&p=4313&hilit=license#p4313
license-8357-985DAD887BFB-0605170051-pro.txt
(124 Bytes) Downloaded 142 times
DICKEYBIRD
Is there any other kinkiness required to do the license unlock other than the file extension change? I downloaded it onto a thumb drive on an internet connected PC, copied it onto the CNC PC & followed the install inst. in the link but CNC12 still says "Acorn free." I'm sure it must be something simple I'm not doing properly.
please find .zip version of same Pro License. please unzip on cncpc desktop by right clicking "extract all"
license-8357-985DAD887BFB-0605170051-pro.zip
(293 Bytes) Downloaded 148 times
then use the utility menu to Import the .dat file as per then instructions.
if you still have trouble please connect the cncpc to the internet and install teamviewer and send me the id and pass (using private message feature of this forum) and i'll remote in and we will go over things.
DICKEYBIRD
Ahh, betch'a that'll do her, thanks!:) I'll find out tonight.
DICKEYBIRD
YAY! I'm a Pro now; if Centroid says so, it must be true! :lol:
(Now I just gotta get the hardware working.)
