Acorn burned down < strand of hookup wire on board>.
Can anyone point me in right direction to figure out this misery. The acorn just died in front of my eyes and I really don’t know why. I triple check wiring and everything looks ok. Where should I look for a reason? It looks like it burned on ground pin and ethernet port
- Plasma CNC Controller: Yes
Re: Acorn burned down
Background would be helpful. Was it a working system before or were you just getting started on a new build?
Describe your machine. Follow this post and provide all the information including what schematic you were using.
viewtopic.php?f=20&t=383
More clear and detailed information will get you better suggestions. Remember, we can not "SE E" what you "SEE"
In the first photo there appears to be a strand of wire sitting on the top of some compts at the top left of the frame. It is sitting on top of C37, C38 and FB4. Given that there seems to be 24V in that area, bad things could happen. Could you have had something else shorting components together?
That's the underside of the ethernet connector that's burned up. Perhaps you have a voltage between the ends of the network cable. Are the power supplies 0V in your PC and Acorn at different potentials?
Ohh crap.. i can see that... good eye. How the hell it get thereMuzzer wrote: ↑Sat May 01, 2021 9:20 am In the first photo there appears to be a strand of wire sitting on the top of some compts at the top left of the frame. It is sitting on top of C37, C38 and FB4. Given that there seems to be 24V in that area, bad things could happen. Could you have had something else shorting components together?
Ok it looks like it was that wire.. i hoped for a miracle and power it back up... i get the heartbeat on the pcb so I was like “no way... it actually might work” so I connected ethernet and power up computer... software on pc recognised it and connected to it successfully and after 5 second bang and it was up in the flame againMuzzer wrote: ↑Sat May 01, 2021 9:20 am In the first photo there appears to be a strand of wire sitting on the top of some compts at the top left of the frame. It is sitting on top of C37, C38 and FB4. Given that there seems to be 24V in that area, bad things could happen. Could you have had something else shorting components together?
Clearly you were stripping wire making your connections. I don't see burn marks on or near the wire, but that doesn't mean it wasn't the cause.LenelyWolf wrote: ↑Sat May 01, 2021 9:35 amOhh crap.. i can see that... good eye. How the hell it get thereMuzzer wrote: ↑Sat May 01, 2021 9:20 am In the first photo there appears to be a strand of wire sitting on the top of some compts at the top left of the frame. It is sitting on top of C37, C38 and FB4. Given that there seems to be 24V in that area, bad things could happen. Could you have had something else shorting components together?
I will always do a visual inspection of the motion controller and I will lightly blast the area with air to help ensure none of those wire whiskers are going to cause me trouble. I will also unplug power to the motion controller when I power up my back panel when I am bench testing it and check for proper voltages at the correct terminals. I will go around the panel and do the same.
Chassis Ground and COM should be tied together at the Acorn Power supply to make sure both are at the same potential.
I still ask you to provide details of the build and post overall pictures of your bench test setup. What was connected during the bench test, what kind of drives, spindle drive etc.....Muzzer may well be correct on the stray wire whisker.....but then again....
I’m sure it was the wire. now the acorn pcb looks like it works but ethernet looks like it is gone. I had connected all my cl57y servo drivers and lenze spindle motor controller... ... look at the attached video(video can’t be attached here) so i get heart beat (10 in one second interval the 2 second nothing and then another 10).. now the pcb looks it work. But when I connect ethernet cable then after few seconds it goes up in the flame again and the cnc software recognise it well. I don’t know If I should still try it with disconneced drivers just the plain board or if the board is already gone and it would be safer to just buy a new onemartyscncgarage wrote: ↑Sat May 01, 2021 9:59 amClearly you were stripping wire making your connections. I don't see burn marks on or near the wire, but that doesn't mean it wasn't the cause.LenelyWolf wrote: ↑Sat May 01, 2021 9:35 amOhh crap.. i can see that... good eye. How the hell it get thereMuzzer wrote: ↑Sat May 01, 2021 9:20 am In the first photo there appears to be a strand of wire sitting on the top of some compts at the top left of the frame. It is sitting on top of C37, C38 and FB4. Given that there seems to be 24V in that area, bad things could happen. Could you have had something else shorting components together?
Videos need to be uploaded to YouTube and the SHARE a link here.
Boards is probably damaged. $199 replacement under Centroid. https://www.centroidcnc.com/centroid_di ... ranty.html
Best double check every connection now.
Here is video from my dropboxmartyscncgarage wrote: ↑Sat May 01, 2021 10:24 am Videos need to be uploaded to YouTube and the SHARE a link here.
https://www.dropbox.com/s/41lwp7pt8tswu ... 4.mov?dl=0
So should I try to connect it again with all drivers disconnected or is the ethernet too burned to try? I don’t want to make more harm then good
If it would be just about the $199 it would be nice but I’m in UK so I have to count customs and postage
You can disconnect everything except Acorn power and Ethernet cable and do a basic bench test.
Hopefully your PC ethernet port wasn't damaged as well
