Speed setting on vfd not working
- CNC Control System Serial Number: 0479B7AC0CC0-0410203131
- CNC Control System Serial Number: 0C1C57072225-0107202806
Re: Speed setting on vfd not working
Looking at the OMRON webpage, it looks like the encoder you have is an open-collector version. The acorn requires a quadrature version, i.e. +A,-A,+B,-B,+Z,-Z. Investigate this closer but I think this might be your problem. Don't ask why it works when turned by hand without motor running, some thinks are not for us lay people to know. LOL
Also, I would strongly suggest you use a shielded pair cable from Acorn 0-10 to vfd with shield grounded at the acorn end at the 0-10 connector. Shield not grounded on vfd end.
I think this is the OMRON encoder you need. E6B2-CWZ1X
Thank you for the help I was wondering why it didn't have the a- and the others
I changed vi to ai which I should have done but it still didn't fix my problem with the vfd not changing speed based on the voltage
Do you have the VFD configured for remote input?
- Plasma CNC Controller: Yes
Omron Encoder Part number should be: OMRON E6B2-CWZ6C 1000 to 2000ppr should be fine for encoder spindle
Attached are my notes for a Huan Yang HY Series VFD (do a search on the forums for Huan Yan HY, been discussed A LOT on the forum.
Let us know how you make out and if the notes help you out at all...
- HuanYuang HY Series VFD Setup for 0-10v input 200731.pdf
- (18.31 KiB) Downloaded 114 times
I got it fixed had to use vi there's a pinout on the vfd it's backwards to the other models for some reason
I also got my new encoder today it's a 3600 ppr it should work thank you guys for the information that really helped me
There are actually knock offs of the Huan Yang VFD
Someone sent me instructions when I got it that weren't quite right for my model but the one Marty sent was what I needed lucky I figured it out later the day I posted this the instructions were kinda miss leading at first I've never used a vfd so I figured all this is a good learning experience.
