Emergency Switch
Emergency Switch
I am new to CNC and installing on my mill. I am testing everything on the bench prior to installation on the mill. I am using the ACORN board and have everything working except the emergency switch. I have it connected per the schematic. I have used the wizard and it appears to be enabled on the IN 8 output. The emergency switch on screen works fine.
Re: Emergency Switch
hello.
What schematic did you follow? What number?
Is your switch NO or NC? Do you have the wizard set correctly? Do you have 24v going in on either H1 or H4?
There is no "emergency stop" switch on the VCP (screen), that's a RESET button and they are NOT the same.
Post a current report so we can check your configuration.
2 users liked this post
