Hi, new here on this forum and seeking information to make a Thermal Dynamic A120 plasma to work with the THC.
I have a Dynatorch System that cuts but the THC part does not work. Its old and obsolete so a new system is desired. Im only retaing the table, plasma and gantry . Replacing whole drive and PC.
Can Thermal Dynamic Plasma work with the THC?
I read that Thermal Dynamics were in the testing, but that was years ago.
What are the basic i/o wiring needed to make a generic plasma compatible with the THC?
I have seen the schematic wirings and see the obvious Torch On output to the plasma and the Divided Voltage input from plasma.
Are the 4 wire that is all needed and with the proper signal to satisfy?
Any technical advice to get my Thermal Dynamic plasma compatible is greatly appreciated.
The TD A120 Plasma does have the automated card in it and I am able to change it to different ratios.
I am hoping to have a definite answer.
THC wiring for Thermal Dynamics or generic
- Plasma/Laser Lead
Re: THC wiring for Thermal Dynamics or generic
Thermal Dynamics is not compatible with Centroid's THC.
Could you elaborate why it is not compatible?
Is there a way to make it compatible?
