A posible bad THC board
Moderators: cnckeith, Joey
cfrandse
Plasma CNC Controller: Yes
CNC Control System Serial Number: 880CE03418B3-0306259174
Post by cfrandse »
I bought a Plasma setup a couple of months ago trying to replace a bad controller from another manufacturer. I recently ran into an issue with the THC not responding to the sensors so I connected directly to the Acorn board and they worked. Is there something more I can do to to verify the THC board How do I get the THC board replaced, The order number is 9014. Thank you for your time.
Joey
Plasma/Laser Lead
Re: A posible bad THC board
Post by Joey »
Welcome to the Forum!
Can you please post a fresh report from CNC12?
A report can be created in the F7 Utility Menu.
Did the inputs to the TX board ever function?
What does your Wiring look like? Pictures of the wiring would be helpful
What Schematic did you use for wiring?
The THC is set to installed in the Profile manager's THC config menu , correct?
A replacement TX board can be found on the Centroid website here. https://shopcentroidcnc.com/shop/cnc-su ... -tx-board/
cfrandse
Post by cfrandse »
Yes the inputs did work at one time
The schematic that I used is S15194
The THC is installed in the Profile manager
Plasma2.zip
(8.38 MiB) Downloaded 87 times
Plasma.zip
(8.75 MiB) Downloaded 83 times
report_880CE03418B3-0306259174_2025-07-16_08-11-03.zip
(8.39 MiB) Downloaded 91 times
