acorn board communications error after update <Resolved>
bill4t
Re: acorn board communications error after update
Post by bill4t »
i took the picture closer too so it doesnt look to fuzzy
bill4t
Post by bill4t »
and after 25minutes of it flashing and saying establishing communications, back to this error
Ken Rychlik
Post by Ken Rychlik »
Without trying it myself, it's hard to know. It seems like you have gone through the correct steps. I would probably send it in for evaluation. It wouldn't hurt to send the nuc with it, so they might can duplicate the issue.
Ken
After it fails, what is the IP address of the computer? From a command prompt, type ipconfig /all and post a photo of the output.
Yes, verify the IP address and that you are NOT connected to the internet. If you did any “Windows” updates it may have changed the IP address of the NIC away from Acorn or updated the NIC driver. I’ve never used the NUC pc but I know they use certain Intel NIC chips that have been known to cause issues. Centroid made improvements to the software last year to overcome this but with any Windows update, if one was done, all bets are off.
First thing I’d do is read this tech bulletin and start here:
Also, run the PC tuner again and it will correct any network issues for you. You can download it here:
bill4t
Post by bill4t »
tblough wrote: Sat May 31, 2025 7:29 am After it fails, what is the IP address of the computer? From a command prompt, type ipconfig /all and post a photo of the output.
heres a pic of the command prompt ipconfig results
You are using the shielded cable that came with the Acorn, yes? Is the cable running through a bulkhead connector or anything? Lastly, did you run the PC Tuner on your PC?
bill4t
Post by bill4t »
yes, useing the cable that came with the unit. i have this hooked up ontop of my table so no bulkead or anything. yes, ran the pc tuner several times,
CentroidFrog
Tech Support
Post by CentroidFrog »
You should be able to find an autogenerated report in your old CNC12 installation.
This would be a backup of your previous CNC12 install in your C: drive.
Inside the zipped backup folder you can find a "reportbackup" folder which should have at least 1 report in it.
Whether this will actually be useful or not I'm unsure, but worth a shot.
Can you ping the Acorn? Here's how:
After you do a fresh install of 5.3 do you try and run the software immediately? Since the Acorn needs to be connected and powered up to even install the software it has to be communicating somehow.
If you have Wi-Fi or bluetooth disable both and do a FRESH install of 5.3. Do not connect to the internet for anything.
