AcornSix - Zri Homing with linear scales
Posted: Mon Apr 01, 2024 8:30 am
hi All,
as described here: https://centroidcncforum.com/viewtopic. ... 338#p85338
i am right now busy with building a lathe from scratch. The main functions are working, i am impressed of the funcionality of Acorn so far.
but last week i add some linear glass scales.
reasons for it: i like to improve the accuracy of the system ( by the way the 750W Servos are very accurate ). the limiting factor for that are the inductive homing switches, i have a deviation of around 3-4/100mm, so nearly 0,1mm diameter tolerance after homing, and this is way to much.
so i bought some aikron linears scales with RS422 interface and Z reference Points every 50mm and integrated them into the system. with an adaptor i changed the pinout fitting to Acorn requirements and the scales itself are working gread. setup is easy, accuracy is great, everything is good. but after that i wanted to setup the ZRI Homing.
i found a video in youtube from marty, he is showing how to connect the encoder ports to Acorn to use the ZRI input for homing:
but this is not working for me. the input never closes.
i also tried to use the JMC Servo Encoder for homing, but then realises, that JMC is not supporting Z Homing, since they have no Z-Pulse transferred from Encoder to the Servo-Drive.
so now my question is, how to handle the ZRI Homing with the linear scales ? how to connect them to an input or can i use the encoderport itself to read the Z-Marker ?
thank you in advance.
Michael
Michael
