CNC12 "Sticking" during Macros
Posted: Sun Jan 14, 2024 4:42 pm
Hello
I searched the forum and Google and didn't see any references to my problem. If I have just missed an existing thread/solution I apologize.
My CNC is finally in a usable state and I have been experimenting with some success. However, yesterday I noticed something odd.
CNC12 would stop at random points during zeroing macros. I could press the cycle-start button and it would continue. The "single block" button was not lit during the hang ups. I have included a couple of pictures.
Now that I think about it, it seemed to only happen during the Zero macros. I have my CNC set up with sensors for auto zero and squaring. The first time it hung up I wasn't sure what to do and I think I clicked the "reset home" button to make it try again. It kept acting squirrely so I restarted the computer and CNC12. When it came back on I pressed reset and then cycle start to start the auto zero/square process. I could be wrong but for some reason I am thinking it didn't automatically run it. (Not sure now... it was late last night)
I would go out there and test but we are in the middle of a winter storm and I have shut down the shop.
The machine seemed to run fine otherwise. I ran several jobs and they all worked fine. It just seemed to hang up as I was zeroing either single axis or zero all.... or the auto zero/squaring.
I have a grade or two higher than recommended Intel NUC and I have followed the setup for the computer. I even checked task manager to see if the resources are being taxed and they aren't. Every cable in my machine is shielded so I don't think EMI is a problem.
The machine has been running flawlessly. This is the first hiccup. I suspect I have inadvertently clicked something but I can't imagine what. I have also attached a report.
The only other thing I can think of is that the last job I ran before all this happened I had to stop the machine during a run. I had set the Z height wrong and it was digging into my spoilboard. The machine didn't throw any errors and it didn't even seem to be straining so I can't imagine that would have anything to do with it. I am just throwing it out there in case it is relevant.
As always, I sincerely appreciate the help.
