Setting up Spindle Load Meter without spindle encoder
- CNC Control System Serial Number: A901313
TB 296 doesn't work for my CNC setup. I have a Delta Inverter VFD055E43A and a Teknomotor Automatic Toolchanger ATC71-A-ISO30-LN S1(3.5kW)S6(4.6kW) 12krpm max24krpm without encoder. Can someone help?
Re: Setting up Spindle Load Meter without spindle encoder
Supposing that you want to use "axis #6" for spindle information:
1) Set P35 = 6
2) Set P313 = 0
3) Make the PLC program assign the spindle load meter value to SV_METER_6
4) Leave P78 = 0
1) Set P35 = 6
2) Set P313 = 0
4) Leave P78 = 0
