lathe spindle question
When switching from auto spindle control to manual, the software sets spindle speed to zero (or very low) Is there a parameter to make it stay at 100% ? Small problem I know but would save pressing the button every time I switch.
cheers
cheers
Re: lathe spindle question
That is a function of the PLC program.
Typical PLC logic is like this:
As you can see, it sets the spindle override percentage to 10% on an auto-to-manual mode switch. This results in a speed that is 5% of the maximum RPM for the current spindle range (10% of half speed).
You can change that behavior to whatever you want, by changing the second SV_PLC_SPINDLE_KNOB assignment, saving your changes, and recompiling the PLC program.
;--Adjust spindle override when entering manual or auto spin mode
;Set the override value to 100% when spin auto mode is first selected
IF SpinAutoManPD && !SpinAutoModeLED
THEN SV_PLC_SPINDLE_KNOB = 100,
SET SpinAutoModeLED
;Set the override value to 10% whenever manual mode is entered
IF SpinAutoManPD && SpinAutoModeLED
THEN SV_PLC_SPINDLE_KNOB = 10, RST SpinAutoModeLED
Ok, I think I get what to do but not sure where to find this piece of code to change it?
default is 50% of max RPM. this is a safety feature so spindle doesn't go to max rpm when you switch to manual.
what is your max rpm set to for this machine? post a fresh report.zip so we can see how you have things setup.
cheers
I never did get this sorted
SET SpinAutoModeLED
Can somebody tell me what/how and where to do with this code please to get my solutuion?
cheers
SET SpinAutoModeLED
You have to learn to work with the PLC, edit and compile....
Easy to implement the code from Marc if your NP++ is set up as recommended
I guess it would help if I knew what the PLC is? Or how to find it?
Related reading:
The file to edit is acorn_lathe_plc.src in the cnct folder
Thanks, thats what i was after
Oh, I'm not sure if re-compiling is above my pay grade. I've managed to make the change in the code though but not sure about compiling...hmm
