Been wanting a lathe, manual or CNC for a few years. This Techno-Isel CNC Servo Lathe popped up cheap on FB and I jumped on it. It's fully operational and appears to be barely used, but Techno no longer supports it and there are no post-processors to be found. The controller is very limited as it was originally intended for educational use.
So, since I've already done one Acorn/Clearpath conversion on my router and cracked the code, I'll do the same with this lathe.
Here's what is on order:
Acorn Kit w/ Lathe Pro
Clearpath CPM-SDSK-2321S-ELN NEMA 23 98 oz-in continuous
Teknic IPC-5 power supply
EDIT: Intel NUC Micro PC i5-7260U 2.2Ghz
